Family Tradition
The PTC i'm speaking of is out of Alabama Roger. Again, Great folks.
http://www.ptcrace.com/
Prop/Wil can you give some particulars on what spec.'s, size, style, options etc. & what they actually said/recommended & are building for you or putting into your specific needs for the Torque Converter, "for your beast"... or did you just buy or them recommend, a 9.5" TF converter advertised on the site ??... I'm just curious what they had to say.... besides this great thread/book, needs to go over 100 pages...LOL....
Hot damn Will!! 632/696!!! WOW that's freakin awesome! congrats brother!!
love it when a plan finally comes together!!
Pretty good convertor builder right out you back door in Kimberly Will.I think the name is Automatic Rebuilding inc.Guys name is Pat Flynn and he is on Kennedy Ave justoff 441.Been doing it along time and always excellent trannys and convertors.
WOW, holy **** that's amazing. Can't wait for more vids. Great numbers, awesome build. Saved the specs you posted, if I ever get the money tree to bloom I'll be contacting you for more info. Congrats!!! Eagerly awaiting more video :headbang:
Simply Awesome!! Gives me goose bumps watchin' the vids. Congrats on the output!!
How cool is that!!!! Daddy likes!!!!
Thanks Fella's! I was presently surprised with the amount of power she makes. Glad to she you share in the same excitement I am. Also, just love hearing the sound of a solid lifter cam engine.
LOL. Yeah, book is right amigo. Not an off the shelf unit budnicks...Looks like I won't get the converter till after memorial day, being they have to build it. They're setting it up for foot brake 2200-2500 and stall 3500-3800. Did a lot of talking with Tim at PTC about all the specifics of the car. Had to pretty much make a decision right there if I was going to lay down some cards more towards more street or all out drag. They put me right on the edge of street vs. strip. Much more up and they specified the car would be bucking like a bronco at the stoplights trying to keep its lungs clear. Pretty pricey...but why skimp out now
You bet brother!! Gonna have to plan a rendezvous with the GTX and bird. Maybe terrorize the streets of Chi-Town or north of the Cheddar curtain
Good to know Jay....I thought the only game in town around here was down towards Oshkosh (ATS and Fox Valley Transmission). Either one of them aren't the greatest to deal with to begin with. Thanks again, I'll save that info for future reference.
Ask Professor Prop,
Hi Prop, I have a question about your block. Did you say it was a late 70's truck block? If it is, they are thin wall by design right? How did you bore it out enough to accept the 512 cid? I understand it's a stroker kit and it's the stroke as well as the bore that's been changed but from what I have read a thin wall block can only be bored .020 over. Did you sleeve the block? I have a 77 440 block that I would like to use to get to 512 like you did but I'm afraid of the thin wall cracking.
Sincerely,
Cracking up in Michigan :)
Ask Professor Prop,
Sincerely,
Hi BigBlock61, take a look at what 440source has to say about the thin blocks. It seems that the later blocks may be actually the preferred ones.
http://www.440source.com/blockinfo.htm
Prop/Wil I commend you, your doing all the right things & the proper converter behind a high HP/TQ stroker engine ain't cheap {my last modified custom N20 3800/10.5" stall converter, was about $800 "I think it was", after all said & done, stainless stator, reworked impellors & ballooning plates etc.}, I wish my old tranny guy was still around, a truly great tranny guy, especially for Mopars are few & far between... I can't wait to see the 1st video, you probably can't wait to make it too...LOL... you spent all that money doing everything right, the 1st time, you can't start cutting corners now... IMHFO way too many people seem to do that, put a ton of cash into something & then put a $150 headers & a $150 converter or what ever, then wonder why it don't perform how it should, get cheap on parts they really shouldn't have.... sometime you actually do get what you pay for or work hard & do your research for a great outcome... Have Fun, I'm sure you will...
thanks for the article Photon
Well we and more importantly you just have to wait a little longer to finish and get this beauty put back together but it's better parts in the end and that just means there is more suspense and drama for when the beast finally get's unleashed making the finale even sweeter. Just like first sex, X% of the fun is anticipation which makes the excitement build! I won't even attempt to quantify that X because as we all know achieving the objective is pretty awesome too!
I hope that comes across in the way intended LOL!
Ask Professor Prop,
Sincerely,
IMHFO I think that's just an Internet "wives tale, fallacy", there's very little differences in the casting, some material casting formula changes, core shift is more of an issue, than a supposedly a later years "thin cylinder wall casting" or nickel more or lack of nickel content in the B-RB blocks, in the B Low Deck blocks the 400 series is a better block, than the 350-361-383 blocks, the 400's main webbing is strongest, if you building a High HP/TQ B-RB Mopar wedge engine, you should use for block strength, a block girdle & main cap studs, "at a minimum", then some better cap materials {& even cross bolts, but it ain't cheap}, if you want to be more safe, but below 500Hp or so it's not really necessary, but it's relatively cheap insurance, if you already spend $2000 on a stroker kit & $2000 for a properly done set of heads, $1000 on machine work, $1500 on fuel pump carb & manifold, larger A/N lines regulator & larger sending unit, $700 on headers etc., then another few hundred, for block strength, isn't too much to spend, to protect your investment & peace of mind...
Thanks guys!! Pretty sharp folks around here. I tell ya, the amount of knowledge/resources/experience you guys have is very impressive. Much to be respected.
This really is going to be a car to be reckoned with Will.. Hands down sinister mean in looks and sound! Wont be long now and you'll have a grin that will keep you up at night! Very well deserved to!
Damn it Will, 632/696!!! This will send the bird into the 10`s!!!
When I getting tired of my nissan micra style 383 I will build a copy of your engine!
Can´t wait for the first video of the car twisting tires on all gears!
:3gears:
Thanks Joakim! Appreciate it, and it's great to see your Coronet so close to making its way to the streets of Sweden. Your Dodge resto has been a great thread to watch come to life.
Enough talk...got that motor in the car!?! ha ha ha
She's close Gpuller...Just waiting on the torque converter from PTC (motor/tranny are going in together). Down to just buying little odds and ends, so it's real close!!
It's those odds and ends that get to be a pain. We will be waiting patiently waiting for the video.
Reed
After weeks and weeks of reading as well as taking this thread out to the garage with me to duplicate on my Coronet what you have done on Skeletor, I can say I've read the whole thing! I have this sudden urge for a Leinie, some barbeque, crab legs and a hair pie. :) I've even gone back to your post on welding in the rear frame rails and now know that I need to go back and weld the inside as well. I was wondering if that was a good idea but now it's going to happen. You are an inspiration as well as so many others on this site to someone like me, who has knowledge but no real experience with restoration. Thank you for posting your knowledge. If you're ever in the Detroit area let me know, I'd love to buy you a cold one and shake your hand.
John
Reed
You got that right Reed! Heck, i'd rather be welding on quarters than dealing with all the trinkets.
John, very nice of you to post those kind words, and thanks for taking the time to go through my novel on the roadrunner. I'm really glad to hear there's folks like yourself that can take something from this restoration and use it to put their Mopar back on the road. That's really good stuff! Looking at all the restoration threads on FBBO is quite amazing. The amount of knowledge and skills folks have is truly amazing, and I for one have also taken a lot of knowledge and know how from what others have posted. Best Mopar site on the net! Thanks again and I look forward to watching your Dodge add to the halls of FBBO restoration. BTW........I'll take you up on your offer next time over in your neck of the woods, and the same goes for you if your ever make it over to Northeast Wisconsin.
Looks to die for and a heart that beats with the fire of 8 behemoth stallions........Sounds like one hell of a good time Will. If you ever take a trip through NW Indiana you gotta stop in and give me a ride so I can say I have been inside a monster and lived to tell the tale.
Thanks KB..Cool words! I'll look you up if i'm ever down there.....Same goes for you if you're ever up in Northeast Wisconsin. Take the Bird and your Net out for some pavement stomping action!
You really think the pavement can take that much abuse! :) Couldn't resist that one Will! lol, besides, whatever town you two may be in, if the cops know your coming, they might call in the reinforcements just in case.
