Got it, basically your just making all of the drops start off facing straight up before turning and coming back down the wall. This will be easy since the compressor will be upstairs, I'll poke through the floor, install a 4 way (bottom being a drain) then take off both directions sloping upward both ways adding the T's facing straight up everywhere I want a drop?High pressure and plastic, just do not mix.... those plastic line kits are for DIY's and are CHEESEY.....They are produced for the cliental that either have no access to the proper materials or equipment and or knowledge, or maybe needed for a temp situation. It may be, that I'm just old school, I would run black iron over copper, or plastiflex hose on any natural gas or propane appliance. When I come across a rooftop unit, unit heater, that has been replaced with a premade flex line the only word that comes to mind is.....What a, HACK,.... fast, quick and cheap.
I will kick out some pic's over the weekend, inverted trap means you take your line drop from the 12 o clock position, never 3,6,or 9 position, and usually use a 4 in nipple up, 90, 3 in nipple, 90, and down. I have seen so many main air lines mounted level on the wall, great for electrical conduit, but not water return. Will post some pic's..
As far as Hack jobs go... that's why I was interested in the one I posted. I didn't like the idea of the PEX kits because they'd surely sag and look tacky but this one has an aluminum center making it fairly rigid. From what I've seen installed they definitely don't look like Hack jobs but pretty professional instead.
You've got me wanting to give black pipe another try only putting more thought into it this time. Just priced it through my supplier... 3/4" is cheaper that 1/2"!!! Only $23 for a 21' stick!
