ws27
The only way to remove moisture from air is to cool it. You could use an expensive mechanical means, or you could just try to get the air to give up most of it's temp to its surroundings. I went what I thought was the cheaper and less complicated way.
For the compressed air to cool to it's surroundings you will need piping that conducts heat the best. PVC, plastic, pex, and rubber hose are all great insulators and won't help with heat transfer. Metal is the best. Copper does conduct better than iron, but iron will be stronger. You may not need the strength except maybe where you are plugging hoses in, quick connectors can be buggers at times.
I have an advantage as my business is heating, and I do a lot of steam heat with iron piping, so it was a no brainer for me. My thought was to slow the air down to give it a chance to cool and drop the water out. It goes through about 100 feet of iron, about 60' of 2" and 40' of 1 1/4" I then teed off with Weil Mclain Alumapex which is virtually the exact same thing as the speed air tubing. I used the Alumapex up high and in a circle with 3/4" iron drops.
For normal operation, air tools, waste oil heater, and my blast cabinet, all water drops out in the piping next to the compressor. If i have to use a high volume of air (25-30 CFM) this system doesn't work because the air flow is too fast for it to cool.
I installed the speed air system from Norther tool in my brothers garage in Virginia and I thought it was great. It is aluminum with pex on the inside and outside. It won't corrode, but it won't help much with cooling either. It is decent quality though.
Here are some pictures of my cobbled together system.View attachment 689889 View attachment 689890 View attachment 689891 View attachment 689889 View attachment 689890 View attachment 689891 View attachment 689889 View attachment 689890 View attachment 689891 View attachment 689889 View attachment 689890 View attachment 689889 View attachment 689890 View attachment 689891 View attachment 689892 View attachment 689889 View attachment 689890 View attachment 689891 View attachment 689892 View attachment 689889 View attachment 689890 View attachment 689891 View attachment 689892 View attachment 689889 View attachment 689890 View attachment 689891 View attachment 689892 View attachment 689889
