- 10:26 PM
- Aug 16, 2016
- Central Indiana
Is the pushrod seated all the way into the piston?
Ok, that took entirely too damn long but finally lines are complete. Now under the dash again to hook up the linkage
I have the factory manual drum brake push rod off the car. I only bought the dr diff one because I thought it would be shorter and could lengthen to what you need (that’s what she said, but holding the factory rod in place it doesn’t look much shorter
I’m not saying you’re wrong, I’m telling you what I have and I’m just as confused, I took measurements, look at post #848 and #849I'm serious though. If you essentially recreated a factory type setup, the factory pushrod should fit and the pedal should be lower.
I can try to rubber part off the new rod and see what that doesIt is a head scratcher. From 1500 miles away, I'm confused too.
This right here:
First of all, I measure from the center of the hole to the end but that isn't important at the moment.
Secondly, that rubber grommet on the new one does have to compress a bit to squeeze into a recess in the master cylinder piston. SOME master cylinders are not machined for it, they are specifically for power use only where the pushrod can never back out enough to fall out.
Manual pushrods can pull out if the MC is rusty and you pull up on the pedal IF there is no pushrod grommet in place.
What you're looking for is a machined groove in the sleeve in the MC piston.
Rod is straight, problem is with rod length and pedal travel, but I think I’ve got itI haven’t read the whole thread, so I will ask if the rod from the pedal is going into the master in a level or straight line or is there an angle that causes the rod to be off center pushing the plunger in. I have had issues with this before causing me some problems.
