Thanks guys. This is my excuse for not working on it over the winter and spring. Helping my brother on the Clone. What could be better than an inexperienced guy replacing the back end of a car ? How about 2 inexperienced idiots !
About the only thing I don't like working on is the glass and window mechanisms. Does anyone have a good recommendation on what to use between the vent window glass and the bottom channel for material ? Thought I remember it was about .030 thick.
I also would love to hear any hints on putting the vent window frame assembly back together. I ground the 3 cast rivets out to get it apart for re chrome. What luck has anyone had using something to peen the other 3 casting posts over the channel to lock it in ? This stuff was taken apart overa year ago and I can't remember if there was any sealer in between the two or not.View attachment 214062
On the a/c cars that I've seen, the Scat Pack Bee is at the rear of the glass, and the a/c decal is near the front.Worked a few hours on the car today hoping to get the interior finished so I can go onto getting the driveline in. Have a question about the airon condition sticker that goes on the passenger side rear window. The instructions that came with it say that cars with the scat pack been emblems the sticker moves from rear corner to front of the window at bottom. My car appeared as it was still in original condition when I bought it, and the AC sticker was under the bee in the rear corner. This car was built in LA so not sure if that means anything. I would like to just redo the car as it was in this picture I took before tearing into this project. Has anyone else seen this or could the cars of been either way ?
If did dyno the engine as it goes into the car with the exhaust manifolds. The only change i had to make was a carb change . I had the old original holley rebuilt and re-dyed by some good carb guys, but they were in the process of starting to use their own gaskets made in house and we're found to be just too hard of material for die cast carbs. The fuel leaked out of my carb in so many places that I was afraid of a fire, so I had to put a shop 650 dyno carb on and run the engine. I did this on the 4th of July weekend along with my brothers engine so I didn't want to have the dyno tied up for days while I waited for the carb to get back.So what were the dyno results? As a mostly stock engine, did it perform as you had expected/hoped?
Engine made 360 hp @ 5400 rpm and 407 tq at 4100 rpm. Was richer than it needed to be with the different carb but I didn't care to change jets as I was primarily concerned about no leaks and timing settings. If I'm not mistaken it had 16-17 inches of vaccuum. I'm happy with the results. Wish I was driving it but I'm getting closer as the engine will be going in within the week.
