Pretty much completed my dash. I still have a new secondary fuse panel to add for non-stock accessories, but the stock dash is done except for the 'hockey stick' dash bezel over top of the glove compartment. My repair for that failed when I put it on, so I need to fix it again. I might to try and hold it on with Velcro instead - we'll see...
My refurbished gauges came back.
My odometer was not cleaned up, so the numbers are a bit yellowed - Oh well, I guess that maintains some of the car's patina!!!
Note the far right gauge - no longer an alternator - it has now been converted to a voltmeter.
I bench tested as many gauges as possible, including the voltmeter and the fuel gauges. Here is an original fuel sender. This one, like many replacement units, only read about 7/8 at most.
Here is the sender from my Fuel Injection tank.
This one made the gauge work perfectly, so no extra work!
Here it is in mounted in the dash.
