Work, Work, Work!
Of course, I didn't get as much work on the car as I had hoped, but I still did make good progress.
First, I installed the rear shocks - Bilstein's from PST! Nice easy and quick! I also hooked up the brake line
Then I installed the tank - I wasn't sure how it would fit since it is a custom fuel injection tank. They recommend a thick pad to reduce any vibration from the fuel pump. I ended up using a work mat - it was nice and spongy and I cut it down to fit the top of the tank. Picture shows two, but I ended up using one only.
Damn rotation got switched again :angry4:
Installed tank from the rear. The filler still needs to be cleaned and cut down, but I won't do that until I have the rear bumper on.
Installed tank from the front. The lower left blue tape is a drain plug - nice!
I then painted the interior floor boards with Eastwood rust Encapsulator to ensure no rust takes hold - no pictures of that - not real exciting. What is more exciting is the first test fit on the engine/K-Member.
Engine basically in place. This so I could fit fuel injection parts and A/C components as neatly and hidden as possible.
I installed the washers to help me understand the placement of some parts.
I KNOW the back of my head will regret installing this!
This is the fuel pressure sensor for the Fuel injection. This location sits behind the passenger side head. There is enough room, and it will be mostly hidden from view.
