So I looked up some horsepower and torque conversions.
Horsepower is easy, as that is all over the internet. by calculation, I made 547 horsepower.
I did find a torque calculator to convert from a chassis to engine dyno. When I plugged into that calculator, it is estimating my torque is 675 lb ft.
I do think that on an engine dyno, without all my accessories, with large headers (mine are only 1 7/8"), and a large carburetor I would likely break 600 horsepower. I think this engine has it in it if it wasn't a bit restricted. But as I said before, it drives
extremely well so I will likely not mess with it.
I had to so some research because I did not ask him. From his website:
Dyno is
a Dynocom 2WD 5000 Series Dynamometer. It can support FWD/RWD vehicles. The 5000 series is the world's best built 8.75 Inch cradle roll dynamometer. It is capable of supporting speeds up to 175+ MPH and 5000+ ft lbs of torque and its track width range is 36"-86".
Ed, you are correct that I messed up. My small phone made it hard to scroll around and I must have goofed up. It is actually Watauga Lake. Route 321 goes right beside it and it was a beautiful part of the ride!
I have now gotten home after an 8 hour drive. I discovered that my vent is still problematic and pisses out quite a bit of fuel whenever I fill it up. So I stopped doing that but threw out any mileage calculations I had made previously. Also, during the trip I had lots of time to keep tuning the Fuel Injection settings (and it was learning too). On the way home today I checked fuel economy. 539 miles with 31.9 gallons of gas used.
That's 16.9 MPG!!!
OK, let's assume I screwed up with my fuel gauge (I started and ended in the same spot, just a needle's width above half a tank). So If I used a gallon more then I still got 16.4 MPG. Regardless, I am super impressed. And, this averaging 75 MPH for the trip home.
Well, we can argue if my calculations are correct, if the dyno numbers are right, etc. Regardless, my car is now official:
I'm super happy with the car, the trip and the friends I associated with on the trip! A great time for sure!
