Jeremiah
1/4" toe in is way too much. That will start to feather the outside tread on the tires. 1/8" max!
If you want to get rid of the alignment shop buy a caster/camber gauge from Longacre, use some greased 16ga sheet metal as turn plates and to make things easy on yourself and get repeatable results get some toe plates to lean against the tires so you have a static measuring point. When I first started doing alignments at home with the above listed equipment I would take them in and have my work checked. It was always very close and the money I have saved since then has paid for lots of other goodies.
That said, how does the car drive? Straight as an arrow? Does it feel like it wants to excessively wander? Have you had another knowledgeable gear-head drive the car for a second opinion?
