- 7:57 AM
- May 14, 2011
- On the Ridge, TN
Agreed, Dave.Ed,
440-6 was kind enough to get you Centerforce's directions and they're in easy to understand terms. BTW, these directions are not car brand specific. The stop I was talking about would be between the pedal and the firewall, to limit travel. As cornpatch Mo said, most likely that won't be needed. The rubber cushion at the top of the pedal travel can be removed or trimmed to give you more free play if necessary. So, to re-iterate, after installation you have 3 things to check: Setting free-play as the manufacturer stated; Having your wife push in the pedal with you under the car with the required feeler gauges, making sure that the correct clearance is there as stated by Centerforce; and making sure that the throw-out bearing is not pushing the fingers of the diaphram in excessively. You will love the clutch. Easy pedal pressure and great lock-up. What could be better?
One step further, folks either develop a "feel" for clutches or they don't, I suppose.
I've never felt the need to "floor" a clutch pedal myself, nor have I really thought about such things - it just seems natural to me to not keep depressing the pedal after the clutch disengages.
Come to think of it, I can't ever recall just flooring a clutch pedal all the way until it stops against the floor.
Of course, you are conversing with someone who simply didn't even use the clutch on my '89 5.0 Mustang for a few months after hernia surgery back in 1990, either - other than when first pulling away from a dead stop, I just didn't use the clutch at all - too painful, you know.
I sold that car many years later, still with the original clutch (and T-5) in it at 250k+ miles.
Clutches and I just have always seemed to get along. I've never replaced one because it wore out in my life.
