I've been reading AndyF 's "How to Build Max Performance Mopar Big Blocks" and I just happen to be in the "camshafts and lifters" section. He writes a well matched hydraulic roller cam and lifters has a reliable range up to 6-7k RPM.
EDIT: See photo of relevant paragraph. He mentions that Max Wedge ports peak around 6,500 RPMs and that a solid FT or solid roller cam would be better. Hopefully AndyF doesn't mind that one excerpt photo. I certainly wouldn't publish his book without permission.
In the previous chapter on valvetrains, it seems that lift of .650 or below is the range where "special" parts are not required to make the geometry work, although aftermarket components certainly are.
I would agree. Is that your anticipated redline? I don't know modified stroker engines or cam specs well enough to know what the power band of your engine is based on what you have posted.
Since you have decided to go with a hydraulic roller cam and lifters,
the focus of the replies I guess should be on what is the best brand of hydraulic roller lifters.
I'll repeat that the CompCams hydraulic roller cam and lifters in the Pontiac 421 Tripower have been flawless in operation. The rev limiter on that engine is set at 5,900 RPM because of calculated piston speed, and other factors.
Also although they are not roller lifters, my hydraulic flat tappet CompCams lifters have been fantastic, and reliably operate up to 6,200 RPMs with these CompCams springs: 911-16 Valve Springs, Single, 1.524 in. Outside Diameter, 373 lbs./in. Rate, 1.200 in. Coil Bind Height, Set of 16
https://www.summitracing.com/parts/cca-911-16
