Those are not the worm clamps but the collared, solid clamps. And yes, efi rated hose.Those look to be regular hose clamps if so you really should use the high pressure style.
I hope the hose is rated for fuel injection.
I might have been the first to install a Sniper on a Mopar. Holley sent me one of the very first Sniper systems for a magazine article and I installed it on my '65 Coronet. The wiring was a big hack job since I was on a dead line. I talked to Holley marketing back then (3 years ago) and told them that they needed to provide an unterminated wiring kit so people could build their own Sniper harness. The guy told me "good idea, we'll put it on the list" and then nothing every came of it. The harness that comes with the Sniper can only be used in a few applications. Most of the time the owner will need to modify the harness and/or build a new one from scratch.
TI'm on the fence about where to put the handheld display. No great place to stick it in the interior where I can see it. Maybe a stand like what is used for cell phones.
Closed percent is way more important than WOT...
https://www.amazon.com/dp/B076B27WP6/ref=cm_sw_r_cp_apa_fabc_dlT1_-Dw2Fb5ZF4XC4?_encoding=UTF8&psc=1That's pretty neat to be the test mule. As far as the wiring, I like the position of the relay / fuse, there is plenty of battery + and - wires. Coil was about 3' short. The weather pack plugs are long out of the Sniper so no way to clean it up 100%. I zip tied the plugs together along the firewall.
I'll drive and see how it acts. With the key on, I can depress the pedal and get same 93% I get at the Holley. Definitely going wide open, and the handheld goes into red at 93%. At idle, tps is zero.
Done and done! First outing was perfect. Great throttle response, no dead spots. The throttle will take some getting use as it is touchy. Checked after the drive, no leaks and nothing loose.The Sniper TPS never reads 100%. Something in the 90's is as high as it gets. Make sure it reads zero when the throttle is closed and make sure the throttle blades open all the way and then you're done.
If you take data logs when you drive and then review them on your desktop computer you'll learn a lot about the system. If you have any issues you can post the data logs on here or on the Holley Sniper forum and people will review the logs and tell you what the problem with the tune is.Done and done! First outing was perfect. Great throttle response, no dead spots. The throttle will take some getting use as it is touchy. Checked after the drive, no leaks and nothing loose.
I'm going to put more miles on it tomorrow. A weird effect from the efi is the smell of the exhaust. It is definately not as rich and gassy smelling.
Ok....how do I review them on my desktop?![]()
Holley has videos on the subject:Ok....how do I review them on my desktop?![]()
The Holley part I linked to opens the rear blades when the front blade opens 40%.Done and done! First outing was perfect. Great throttle response, no dead spots. The throttle will take some getting use as it is touchy. Checked after the drive, no leaks and nothing loose.
