ksurfer2
With the key in the "run" position, I am showing 10.2 volts to the coil (positive prove on + side of Coil, negative probe on same ground the distributor ground wire is attached to).
With the jumper wired as pictured above, I am getting 10.2 volts to the coil. Should that be enough?
Is that what the addendum says, something about adding a relay? I can't read it... if the system absolutely has to have a full 12 volts before the motor starts then that would be the way to do it...According to the addendum, NO
Thanks. I will try all that in the morning (before the in laws show up). I did manage to grab a new MSD coil from the parts store (thank God they stay open late!). Tune back in tomorrow morning for further updates. Right now....beer time!Mine shows 10v on the start wire also, with the car off and key in 'run', that's not the issue...if you want to verify that you can do what you mentioned earlier and run a jumper from the battery to coil +. Carefully...and just long enough to check as you will not have any fused protection in the circuit. But I think something else is wrong..unless you have a helper to turn the key, set your phone up so it can record video of your meter, measuring coil voltage while you crank the engine...(let's make sure you're also getting coil voltage during cranking..)
https://documents.holley.com/frm33565_ready_to_run_add.pdfIs that what the addendum says, something about adding a relay? I can't read it... if the system absolutely has to have a full 12 volts before the motor starts then that would be the way to do it...
The coil is wired to the distributor as pictured in the instructions above. Absolutely no hate for mentioning...All here have been very helpful.And, don't hate me for saying this but.... The coil wire to the distributor is connected properly right?
Your welcomeThank you!
Yeah no worries...I was meaning the (secondary) big fat wire to the distributor cap though...(ugh so many of us have forgotten to reconnect it lol!)The coil is wired to the distributor as pictured in the instructions above. Absolutely no hate for mentioning...All here have been very helpful.
I doubt that is the issue. The motor ran fine on the dyno just last week, and nothing was changed during the install (carbs, distributer, all stayed on the motor).And if all is correct you may have a bad ignition module. This was the problem I had with mine right out of the box. Later verified by MSD techs.
Told them to keep it and went a different route.
I made a new one, and when it wasn't working, grabbed the old one that I new was working, no change.Yeah no worries...I was meaning the big fat wire to the distributor cap though...(ugh so many of us have forgotten to reconnect it lol!)
