70B5Cuda
The drivers side quarter didn’t get replaced so that’s why Matt used that design...it had to be installed from the wheel tub side.
Uhhh...I had to learn for myself.The guy that cc’d my heads used rubbing alcohol. He said that water has to much surface tension and it’s too hard to get the air bubbles out.
Hey, the most important thing is you are out there giving it a try. This is the way we all learn!Uhhh...I had to learn for myself.
It was 96 out in the shop, the Vaseline was so soft it was like melted ice cream. It was hard to get the Plexiglas to seal.
The water would not fill the chamber. It got up past the valves and formed a wall in the area that is the quench zone in those types of heads. I had a fill hole and an air hole and the water would push out of the air hole even though the chamber wasn't full.
It has been a shitty day.
Use multi purpose grease to seal the plate, set head up level then tilt it around to get air bubbles to bleed off at the fill hole.
You won't regret those. When I restored my 70 Road Runner, I added those plates, a sector support kit, Firm Feel stage II box and a full US Car Tool body stiffening kit. Those pieces, along with all new wear parts in the suspension made my car steer and handle like a dream.I made stiffening plates and welded them on today.
