Looking for help finding a very rough idle cam for my 440
69_roady
5:16 PM
minnesota
Looking for help finding a rough idle cam kit that will make my 440 sound like its beefed to the nuts while iddleing at the pumps
my 440 is pretty much stock, is bored 30 over, stock heads, dual plane edelbrock intake,, 750 holly double pumper,, headman headers with cherry bombs ,2 1/2 " outlet, no tail pipes,, 4-speed trans, not sure on gears but just a step or two above 4;11's
i know nothing about duration and all that.., my 440 4-speed has lots of power as it is ,,, im after the thupidy thump rough idle and lots of burnout grunt ,, dont need to go fast ,, so any exra power is just a pluss ,,
help on this is very very much appreciated
i see comp voodoo cam kits on ebay ???
Ggo to Comp cams and look at their THUMPR CAMS if your looking for sound this is where you want to go. Good people to talk to they will help you out.
Went to comp cams and sent my spec's and info ,
takes a couple working days to hear back ,, ill post
when i hear back from them what they choose for me, :)
Thanks for the great advice ja20
Well, if your car already runs good and has plenty of power, run a vacuum hose from the intake into the passenger compartment, put a valve on the end that's easy to reach and when you want the idle to sound nasty, open the valve. I just saved you a couple hundred dollars! Sorry, couldn't resist :D
well, if your car already runs good and has plenty of power, run a vacuum hose from the intake into the passenger compartment, put a valve on the end that's easy to reach and when you want the idle to sound nasty, open the valve. I just saved you a couple hundred dollars! Sorry, couldn't resist :d
lol
I was thinking a timing retard.Along the same lines. lol
