For the record, I am not asking if manifolds or headers are better. Everyone should know the advantages of headers, and the power they can add (if the mating components can benefit from improved flow). My question was if HP manifolds would be sufficient if I am just building a cruiser and just want a little extra torque over stock. I am using stock 906 heads, which everyone says don't have a lot of flow, so do I really need headers to build a nice cruiser motor.
We all have a budget, and body work is eating up a substantial part of that budget. I have 2 sets of 906 heads, 1 set of 915 heads (currently held for a possible 400 rebuild in the cuda), and 2 sets of HP manifolds. If I could save some money by using the components I have and still build a decent torque motor for the street, that would be helpful.
Hence my questions of:
"Can I get away with using the HP manifolds and still get good low end torque performance for the street?" (Yes/No) and "Can someone recommend a good cam to go with this type of setup."
Car has AC, and vacuum accessories for headlights and heater/ac controls, so I want a good torquey motor with good vacuum. I looked at some of the cams suggested by some, and it looks like duration on those is running from 208 - 224 on intake and 213-241 on exhaust. Lifts of those three cams suggested are .486/.473, ,454/,454, and ,466/,488
Sounds like if I want to build low-end torque, I would want a decent lift, with less duration and overlap. Am I understanding that correctly?
Specs I know of at the moment:
Forged pistons, shooting for 9.25 SCR
Stock 906 heads
Likely stock intake, possible Edelbrock RPM intake (to avoid need for adapter to fit aftermarket carb)
Stock '69 HP exhaust manifolds through 2 1/2 dual pipes out the back. Likely Super Turbo or Magnaflow mufflers (quiet but rumbly)
A833 4 spd
8 3/4 Sure-grip with 3:23 gears
Car has AC, power steering, and manual brakes
Likely 255/60R15 rear tires. Maybe 275/60R15
