If anyone is still interested, here is the current status. The new flooding issue at idle was being caused by the new float slightly hitting the vertical metal tab that sits under it and kept it from closing completely.
Noticed this when swapping the original floats back into the drivers side carb. Those tabs were bent on the carbs I rebuilt and I had straightened them up when they did not want to go through the top gasket cleanly.
Now with that out of the way I took another test drive. Only went about a half mile before the "blue/gray" smoke started again. Came home and shut it off and restarted, but this time it kept smoking.
Now it smokes (pretty sure its oil) all the time. Not a good sign for sure.
So considering that the compression tests seemed to pass, the intake gasket was replaced, combustion gas in radiator test passed as did cooling system pressure test, what might be the cause of buring oil from startup to shutdown, both cold and hot?
I know it is likely bad news, what else could it be?
Could a compression test with engine warm have shown different results? It now smokes old or warm but wrose when warm I think.
Would a leakdown test on each cylinder tell me anything new?
Can a head gasket let oil into combustion chambers but not affect the cooling system?
Would sticking rings cause oil burning and would they have shown up in compression tests?
If anyone has ideas they are
all appreciated. More than likely this is at the point where I just send the car to a Mopar shop in Atlanta and wait to be told a rebuild is needed
Note this car was restored between 2003-2005. Since that time it has only been driven 2500 miles or so. That means it has mostly been stored. Worst thing you can do to a car. Adding this info just in case that might shine a light on possible causes.
Thanks!
