Eggo
Hi, i’ve had my 73 satellite for just over 3 years now. it has run very consistently temperature wise in that it always sits with the needle on the left line of the U shaped section between the C and H marks (hope that makes sense). Recently it’s been creeping up above this which is really out of character for it and it seems to creep up more when i put my foot down a bit. I’ve changed the water pump as think this was leaking a bit and have changed the thermostat yesterday. The thermostat i put in was a 160. Have just taken it for a test drive and it seems to be getting hotter even quicker now which is really weird. Why could this be? the rad doesn’t appear to be leaking as the level doesnt ever go down really. Have included a photo of where it was sitting when i got home and this was with the electric fans on which normally cool it down really well. When i was driving back the needle was higher than what it is now. Not sure if maybe it could be the gauge playing up so guess i should get one of those gun type temperature readers (technical term lol) and have a go with that just to double check?
The weather over in the UK at the moment isn’t that warm either, i took it 300 miles down south a couple of weekends ago and it was maybe 15 degrees max and it was doing it then as well. Have dailyed it 3 years through some 30 degree summers and it’s never overheated or really shifted from where it usually sits. It doesn’t have a fan attached to the block but just the electric fans. They’re definitely on and working as i wired it to a switch in the cab so i put them on manually. Usually i only need to turn them on when going slowly round town and in traffic but recently they’ve been on constantly, even on the motorway, and the temp gauge has still been creeping up.
I definitely need a more accurate temperature gauge, have got a moon eyes one sat in the car but the place where it should attach in the engine block the thread is messed up further down so i can’t fit it
