US Cartools . . . follow up . . .
With my calculations and concerns on the 3/16" movement of the spring relocation, I gave Chris a call at US Cartools. We have a 45 minute discussion on the spring relocation brackets, the pros, the cons, what I had in mind, what they were considering, and it was a great discussion. He informed me that the 3/16" movement would probably not be a concern and it could actually help with 3'16" extra clearance at the front of the wheel well.
BUT, he also offered to make me a new set, with the holes relocated 3/16" forward so everything will be correct, which then got us talking about the rear spring relocation concerns . . .
Here's the difference in the frame heights - this shows the hole for the original spring shackle:
And this shows the difference in the height of the two frames in this area:
Well, US Cartools is in Durham NC, which is about a 1 1/2 - 2 hour drive, and Chris has invited me up to see the facility, said that he should be able to get the new brackets done by Friday, and we could swap them out. He also said he'd like to discuss the new plans that they had been tossing around - the reason they hadn't pulled the string on it yet was the amount of fabrication work that will be needed to make the new hole support the original shackles and work properly. I've already put in for the time off from work on Friday and it looks like I'll be making a road trip to Durham to see the US Cartools facility and talk to Chris. By the way, he seems like a great guy and was very easy to talk to about his products.
I'm looking forward to the adventure ! ! !
