wedge69
SoFar so good ! Keep it up as you ALOT closer to the pavement then I am !!
Nice work GearAddict!
I have the same disk brake upgrade. Did you install the anti-rattle rubber bands and clips on the brakes? Any pictures of how the bands go on the brake pads? I saw the anti-rattle stuff but haven't yet started to ponder how it fits.
...and yours looks a lot better since your is actually attached to a car!!! :yes:
Nice car! I too am on a similar budget...but there is always plenty to do that doesn't require much $. Im guessing your car doesn't have power brakes... where did you get that front disc brake kit and how much does it cost? I don't think I want to switch to power brakes and am curious if manual front disc brakes are worth it for the money?
So...having never seen one of those disc break conversion up close and personal, have a few questions. Are the bearings installed with the rotors? Are they all one unit? Did you have to remove the lower ball joint from the LCA....or can that just be unbolted from the backing plate? I assume the upper ball joint (control arms) needs to be removed.
Thanks! Looking great!
Looking good GearAddict! I'll be checking back here to compare when I work to put mine back together. My K Member is mostly done except for my steering box, so now I am working on the engine and tranny. Hopefully soon I'll be doing some of the same work on mine!
Keep up the good work so I can keep copying off of you!!! (smile)
I see the console has the girlfriend crack, or at least that's how mine got cracked back in the day![]()
Looking good GearAddict! Gives a guy a good feeling with all that new hardware under there don't it? I see all that hard work paid off for you.
Nice job. Interested to see how the center console turns out.
Any idea when you might be driving her?
Keep up the good work!
Sunday update... Brakes bled, had to tighten up a fee of the fittings on the new lines to get it done. Tried using one of those vacuum style bleeder tools, but it was a pain in the but. Ditched it and got the wife to pump the pedal old skool. Good to go.
I'll take it to the alignment shop this week...anyone got recommendations on alignment specs for the shop that are better than what's in the FSM?
Great thread GearAddict, thanks for documenting all your work and research. I can see it saving me a lot of time in the future, I just subscribed to it.
Nice going with the brake job. My wife will help as well, but it is much better to have my son do it because he is actually into cars...
As far as alignment, you may want to check out one of my old threads:
http://www.forbbodiesonly.com/moparforum/showthread.php?42038-Help-Needed-On-Alignment-Issues
Good Luck!
Hawk
