Ok......lets see the gouge.
I wasn't going to ask, probably miserable enough without showing it off to us haha. Put a sticker over it!
Devin, when you met Maria on Saturday she was my girlfriend; on Sunday she was my fiancé.
I'll be hitting it hard now, only got 10 weeks.
Good luck buddy, Ive been with my wife now 43 years, married 38, i pray you have a ball with all this,,, i would love to do every thing over again, my lady and my cars!!... And your work is going good looking at all the things you've done... :happy11:
Congratulation on the engagement !
Hawk - awesome write up. I had started drawing a wiring diagram right after you left; I need to post it and get your input. You probably remember when looking at my dash that the black and red ammeter wires are soldered together so they just have to be cut apart. I was researching fuse blocks on Summit that other FBBO members had installed. They are designed to use a jumper wire from a switched circuit on the original block over to the new block. If I understand correctly, this eliminates the need for relays but the new fuse block is in series with the old, instead of your design that's on its own circuit protected by an independent fusible link.
The red 12 ga wire running between the bulkhead and the ammeter must be a "run" circuit, which is why relays are needed? Excuse the rookie questions, I'm still enrolled in Automotive Wiring 101.
Thanks Roger. It's getting there.Quite a work in progress. Thanks for posting.
Hi Rich,
Nice progress!
As you saw with my car, my fan and pulley setup is a bit goofy since it has the low mount "hidden" compressor. Your setup is far superior to mine, so I don't think you will have near the issues I had getting my compressor to work quietly and reliably. Having said that, take the time to get all this stuff to line up well, or you may likely have squealing belts and hassles down the road…
Engine looks bitchin' sitting between the fenders! :headbang:
Nice progress Rich!! Man you have been jamming on this project lately. It looks bitchin'. Hey I tried to PM you but your inbox is full. That thing going to be ready for spring fling April 23? I will be bringing my car for the first time.
By the way, don't forget to grease your suspension fittings like I did...
