Made it through another Christmas
but just barely. This restoration consumes a lot of time, so after we spent all last Saturday installing the engine I had to take the next 4 - 5 days catching up on shopping. Got it all done on the 23rd.
I wound up receiving some cool car gifts - a couple of Mopar hats, a T shirt, mechanics gloves, an LED trouble light, another fender shield and more wall art for the garage. It was a great Christmas all around, but back to last Saturday…
Here's pics of the mini-starter and the post extenders that need to be removed:
Used nylon tie straps wrapped around the bumper.
There was plenty of room to raise the car.
Oh yeah, lets not forget about the transmission mount. DUH!
It's in!
Take aways:
Could have used a 3rd person; one on each side to guide while one person works the hoist.
We spent so much time worrying about the headers and motor mounts we didn't spend enough time on the tranny. As a result one of the tranny mount ears got bent as the body was lowered and it got caught on the crossmember. We wound up taking out the mount and straightening it in a vice.
Also bent the stainless steel kick down linkage where it attaches to the transmission. Haven't determined yet how bad the damage is.
The whole operation took about 4 hours with two guys, so we didn't save much time from going in from the top. Dropping the body is easier if headers are installed; they took an hour to bolt up while the engine was still
out of the car. Starter has to be loose, resting on the collector, then bolted in after the header flange is bolted to the head. Would not have wanted to install the headers after the engine was in.
Another reason to go in from the bottom is to save engine compartment paint. Mission accomplished; but we put a gouge in the front fender moving the hoist around. :angryfire:
If the plan is to restore your ride, rebuild the front suspension, disc brake swap, new torsion bars, etc. then it makes sense to drop the K member and reinstall from the bottom. But if everything on the front end is good and all that's needed is an engine rebuild, I would drop it in from the top.
Next step is hooking up the front suspension, installing the torsion bars and having a roller again.
