Can't believe it's been a month since my last post. Been doing a lot on the project, just need to find the time to catch up on FBBO. My youngest son got married last weekend and surprise!, he and his wife are moving in temporarily. We have a two story with the kid's bedrooms upstairs and a large bonus room and the master bedroom is downstairs, so it works out fine. But to get it all ready Maria and I painted the upstairs, cleaned the carpets and generally tidied up the place. The home improvements and wedding prep ate into much of November.
After finishing the rear suspension it was on to the front. The front end had been rebuilt by the PO about 10 years ago according to receipts, but he only put about 2000 miles on in the decade. So the parts were still fresh. But it's a 4 wheel power drum car so it was time to swap out to disc brakes. The choices are almost endless but in the end I went with the 11.75" disc brake kit from Cass at Dr. Diff. He's a great guy to deal with, answered all my dumb questions either over the phone or e-mail. If you want to check out a more detailed version of why I went with Dr. Diff, plus a picture-by-picture account of how to install the swap, check out the link to my thread in the Brake forum.
http://www.forbbodiesonly.com/moparforum/showthread.php?81037-Disc-brake-conversion-odyssey
This was a good time to upgrade the front suspension, working around some of the parts that the PO had replaced. After doing a little research I ended up going with PST - they're an active FBBO member and it turns out a real good company to do business with. Again, I had a bunch of questions and their CSR's answered everything to my satisfaction. Even though the tie rods were replaced I went with the larger 11/16" with solid adjuster, LCA rebuild kit, idler arm, tubular upper A arms and strut rod bushings.
Nice looking kit:
Lastly i got a pair of .96 T bars from Monicatti Chrysler; the stock T bars were only .89! My Dart has .92's. Sorry, no pics (they look like Tbars :jerk
I first tried removing the T bars the low impact way by loosening the LCA pivot shaft nut and disconnecting the lower ball joint from the tie rod end, backing out the T bar adjuster, etc. and rotating the LCA forward, but no dice. I wound up buying the removal tool from Mancini Racing and it took about 2 - 3 whacks per side and they fell right out. I'll need the tool again when I rebuild the Dart's front end.
I took the K member down and had it and the LCAs media blasted. I then made some cardboard templates and Mike boxed in the motor mount tabs and reinforced some of the welds on the K and also welded up the stiffening plates on the LCAs. Again, for more detail heres a link:
http://www.forbbodiesonly.com/moparforum/showthread.php?79614-Crappy-K-member-welds
Considering it's only gonna be a daily driver the K welding was probably overkill, but we were having fun designing templates and welding it all up. Afterwards I ground 'em down and painted the K with Hi-Gloss Black POR-15, same stuff I used on the new spindles. All things considered the suspension rebuild and disc brake swap was pretty straight forward; it was my first time attempting either one so as I've been saying throughout my thread, if I can do it then just about anybody can.
Man, that engine compartment looks lonely:
Almost forgot, one more link - to my thread on dropping the K. At the time the only other components on the car was the rear end. So when your car is completely stripped down and you're about to remove the K member, make sure the car's weight distribution is biased towards the front. Better yet, have someone helping you. When the last bolt came out my car tried doing a wheelie on the jack stands. It almost tipped over on it's side. Pictures tell the story:
http://www.forbbodiesonly.com/moparforum/showthread.php?78362-Why-am-I-taking-out-the-K-member
