Reassembling the dash
As I started putting the dash back together; three thoughts popped into my head 1) thank God I tagged and bagged everything during disassembly, 2) it's going to take A LOT longer to put it back together than it did taking it apart, and 3) even with all the pics I took and the pages of notes, I'm gonna need a lot of help from all you guys from time to time.
So back to the dash - spent a few hours on it yesterday and all I have to show for it is the gauge cluster, ash tray and map light are in..lol. Most of the time was spent taking pieces off after putting them on trying to fit everything together. The lower dash pad came off at least twice. Can't find the chrome trim that runs along the front of the dash. I have the curved pieces for the corners but they can't go on yet because they attach to the plastic A pillar cover and the dash isn't in the car so the A pillar cover can't be installed. Its like playing Tetris all over again!
Another reason it's taking longer to reassemble is that I'm putting thin strips of insulation on the backs of the dash pieces before installing. Originally I wanted to insulate just the side vents because it's metal on metal. I haven't decided on a cam yet but it's going to be fatter than stock and so I don't want my dash rattling around while idling at stop lights.
The factory glued thin strips of insulation to the backs of bezels, etc., but after 40+ years the insulation had worn or fallen off most of the pieces. So what originally started as insulation for just the a/c vents morphed into replacing the insulation on everything.
I found this foam tape at Lowe's; it was the thinnest and narrowest tape they carried. It's 3/16" thick by 3/8" wide and very easy to cut. And it has good "crush" so even though it's thicker than the OEM stuff once the piece is tightened down there's no difference in the alignment.
Here's a pic of the back of one of the side vents
In between football games i'm planning on finishing up the lower dash pad and switch plate today. Then start re-wiring!
