hunt2elk
Everyone around here uses that green fiber strand stuff over these joints. I've never used All-Metal, I'll have to check it out.I believe most use USC ALL-METAL to fill those joints
Sounds like you got a very hood bodyshop. I don't know of any around here that would offer to do that job without being told, and then they would still complain. Kind of a big job. Back end of the interior would have to be taken out as well as dropping the headliner to prevent a fire.I know when I had Fred in the body shop, he already had one c-pillar that had bubbled up
from the previous owners' dubious painting/prep work, so they asked me if I wanted them
to fix it while they had the car.
I said "sure", not knowing what they actually meant....
when I went out to check on things, they handed me a big wad of (cooled off obviously)
molten lead - they had done BOTH sides, melting out the original lead and redoing the joints
with weld, then filler. They matched paint perfectly, too - it looks fantastic now.![]()
Yes sir, I agree. They did the same thing down at that joint under the doors in the rockers, too - another siteSounds like you got a very hood bodyshop. I don't know of any around here that would offer to do that job without being told, and th hen they would still complain. Kind of a big job. Back end of the interior would have to be taken out as well as dropping the headliner to prevent a fire.
Nice work, repairs look excellentNext up, I found a suspect area at the drivers side floorpan. Sure enough, I was able to stick a awl through in a couple of spots. I debated just welding up the holes, but their was some heavy pitting in the general area around the drain hole as well. It would look better and give me piece of mind to cut out the bad spot. Not that I needed a full 1/2 AMD pan, but for some reason they are out of stock everywhere. Only other option I know of it a Sherman piece. I was kind of nervous about Sherman as I had to use one of their lower quarter patches on my Duster, because AMD was out of stock at the time. There was a huge difference in the stamping between that and the AMD I was able to get for the other side. It worked, but definitely not as smooth of an install. Best price I found was through Summit and it was shipped directly to me from Sherman. I was skeptical at first, but for what I needed it was just fine. The thickness of the metal was exactly the same as original. You can see that the Sherman patch panel does not go to the firewall seam or up top of the rocker like an AMD part would for some reason, but covered what I needed perfectly. Also the hole is not punched out.
Took some good measurements of the gas pedal holes as well as the speedometer cable clip. Left and rear side is butted to original metal on top of frame flanges, and the right side goes into my 4-speed hump area. Only seam that will show is the front edge. I used the piece I cut out as a template for final positioning before welding. On another note, I think I have used just about every brand of weld through primer out there in the past. I hated everyone of them because if you had just a speck of the primer showing, your weld would splatter and look like crap. I am using SEM on this car for the first time and have to say that I love it. Works very well and will be what I use going forward.
Did some experimenting with different hole saws and electrical conduit punches to get the correct 1 3/4" hole for the plug. Ended up using a 1 11/16" saw for the perfect diameter. Turned out nice imo and the front seam will disappear during sandblasting. Nice weekend project.
View attachment 1080895 View attachment 1080896 View attachment 1080897 View attachment 1080898 View attachment 1080899 View attachment 1080900 View attachment 1080901 View attachment 1080902 View attachment 1080903
Hmmmm I don't remember making any holes for the pedal or speedo clip when I patched that area of my floor pan. Thanks for the reminder.Took some good measurements of the gas pedal holes as well as the speedometer cable clip.
East wood has a solider that is stronger than the lead. I used it on my A pillars where the upper cowl meet them. It worked fine Used a heat gun and a putty knife to smooth and work it. Kept the heat on the putty knife and it worked out well. But like others used the All metal in the sail panel area's did not want heat on the metal after rust proofing every thing inside and out. Just my two cent's and hope it all stay's together once the car is on the road.Ok cheers. I think I'll do the same as otherwise it's either lead or filler and I don't like filler and have never used lead. Hopefully it will come out as good as yours did!
So you sprayed the whole bottom of the car with it, and then painted over?
Exactly my thoughts as I was dropping each piece in a pile on the floor, lol.Should pick up a tenth in the quarter mile now!
I bet sometime early in its life there was a small box or can with an open top, or a loose top, forgotten by its owner. 1st hard turn to the right dumped it over. I still can't believe there isn't rust through from all those pieces wedged in there for so many years. Being a Texas car and then having that yellow creeping grease sprayed in there saved me I reckon.Wow! Where the heck did all that come from, do you suppose?
