usaroadrunner
sweet welcome back, told you working on that charger is good therapy...lol:balloons:
Yes it is. I feel much better already.sweet welcome back, told you working on that charger is good therapy...lol:balloons:![]()
It is great to be back. The hard part is that I'm still restricted on what I can lift and be exposed to, but it is great to be doing something again.Its great you are back on your feet again showard. Can't wait to see the continuation of your build. Good luck.
As I built the model I was thinking the same. I was wishing that things would be as easy.Congratulations on the new kidney and very lucky you have a loving brother. Get well and stay strong.
Nice job on the charger model. It would be nice if the real cars went together that fast.
Robert
Thank you GTX. It is great to be home again.Welcome back
Thank you, and thank you for that article about how to take apart the upper control arm. I would have had no idea and probably would have bent up my control arms.Looking good! And good to hear your feeling great!
That is a good idea. I think that I can get most of the junk scraped out. I was wishing that I knew someone with a balljoint socket. I felt that it was a lot of money just to use a couple times.If you can get most of it scraped out, the blasting will get the rest. Just tell your blaster to give it some extra time in those areas. Wish I would have known you needed the balljoint socket, I would of sent ya mine. I'm putting my suspension stuff back on right now.
I took it into the engine shop here in town to see if I could get it boiled but it was just a little to long to work in there machine so I guess I will clean it out the best I can. I will try to do a better job at scraping out the inside and then soak it with engine degreaser and power spray it out. Then take it to the blaster to have it sand blasted.When I blasted mine I could not get down inside of it. (I also tried cleaning it at the local car wash) Then when I welded the around the perimeter I had a hard time. I believe because there was grease and oil inside. If I had to do it over again I would get it boiled like you mentioned.
Good info.I don't know if your getting it powder coated, but I found out that in there process, they do a hot bath.
So maybe that might be an option.
Thanks GTX, I did buy the super front end rebuild kit from PST and I also got the disc break conversion kit, leaf springs, shackles, and engine mounts.Great progress! Have you bought any suspension rebuild parts yet?
