Thank you!
I started on the driver’s side today. I got a bit side-tracked as I was not happy with the door fitment. After fiddling around with it for almost two hours trying to get the body lines matched up, with an acceptable gap at the bottom and trying to match up the top of the door with the top of the quarter, I almost gave up. I could get the body lines all set with an acceptable gap at the bottom but couldn’t get the top of the door to line up with the top of the quarter no matter what I tried. For shits and giggles, I decided to measure the rear window opening at the door on the passenger’s side. And, of course, it’s about 1/8” larger height-wise than the driver’s side. Crap! I had to slice the driver’s side opening just below where it bends and weld it back up. I also had to make sure I kept the angle of the bottom section flat with no aggressive dip. I had to grind a bit of the driver’s door and slice the bottom corner of the quarter and weld up. I also had to slice a bit of the rocker at the corner, as well. And, of course, I ran into the lead seam. Super! I’ll have to fix that later. I also had to grind a bit of the fender too.
Door to quarter all set. I pretty much had to weld the entire seam back up, fun!:
Fender to door all set:
Rear window opening fixed:
The opening was about 1/8” too short on this side (red line):
I had to make sure this angle (red line) remained flat after adjusting:
I still need to weld up the seams I ground back but I’m making progress, I guess.
Thanks for looking and happy New Year!
