Also accumulating some needed transmission parts, a stock converter weighted for a 400 for conversion to a 2500 stall, and a tailshaft housing with the ears for the floor shifter.
Be careful with the short side radius you can use an original cylinder head as a guide as to what it should look like.
My theory is just to round off the sharp edge created by the plunge cut
I guess you don't have another cylinder head to look at.My theory is just to round off the sharp edge created by the plunge cut, but I would appreciate any suggestions or pictures. I will probably finish the port matching I started first
I've got the exact same one. Had to replace the head valves once and I suspect it could use rings, but still working 20yrs laterHere is the new compressor versus the old one. I have to get a new belt and change the oil, but I should be good for next weekend.
I replaced the belt on my father-in-law's unit. On his, you loosened the motor itself.How do you replace the belt, loosen the compressor mounts?
