The thought had crossed my mind, but I jacked it up a little, heated it up and then jacked it some more and heated it again. Hopefully no cracksFWIW, exhaust manifolds can be cracked.
I have a good one for that side.The thought had crossed my mind, but I jacked it up a little, heated it up and then jacked it some more and heated it again. Hopefully no cracks
If it had cracked, you would know it.The thought had crossed my mind, but I jacked it up a little, heated it up and then jacked it some more and heated it again. Hopefully no cracks
Thanks for the offer Don, but I think I am good now. I will know for sure when I try to loosen the exhaust hangers! The exhaust has to come off to pull the engine and trans.I have a good one for that side.
You can continue to dwindle my supply of spare parts if need be.
Well you break it you bought it.More test fitting today. I bent and redrilled the coil mount bracket to fit the different boss location on the Weiand manifold, and I am happy with the result. I decided I am just going to use my carbide burr and slot the coil boss below the yellow mark for bolt clearance. I forgot to test fit the compressor support brackets and the alternator bracket, so I guess that will be tomorrow's job.
I've already done my fair share of grinding on it Don. I figure that support should be solid, otherwise the runner wouldn't have a flat outside wall. Even so the plan is to just grind enough for the bolt to clear.Well you break it you bought it.
Oh yeah that's right you already bought it.
I always said that I never added a part to the car that I didn't have to modify.
