dual fours
- 10:49 PM
- May 25, 2014
- york county, pennsylvania
As some called them anti-theft door lock buttons to match my SE wood grain trim. Sun Super Tach II, really soft fur on the package tray (came from a old coat from the 1930's), M/T cast aluminum valve covers with those Tee handled valve cover bolts and black painted engine compartment that is being removed.The CB antenna at one time was mounted on the trunk forward lip. Then I went to a 4' fiberglass whip on the left side of the rear bumper.
The scanner was a Bearcat handheld. Fog lights mounted low on the Clown lip front bumper. Firestone L60 x 15 on the rear and F60 x 15 on the front. The Charger came with red painted 11" drums so I painted them white. Who in there right minds would paint the drums red? Oh and I filled the window washer reservoir with bleach and water and ran small tubing to both the rear wheels. When stopped at a red light just push the washer button and wet down the wheels and stand on the brake peddle enough to hold the car and push down the gas peddle. This makes an awesome show with lots of smoke. The street fills with white smoke the crowd roars and you look over your hood and though the smoke walks a Cop, busted.
The big yellow pint container size Accel Super coil and yellow 8mm Fat Stuff plug wires.
You always found something left in the car when cleaning it out on Monday night, a necklace (puka shells where in then),stockings, bra, phone numbers on a napkin, rabbit fur (yes real rabbit fur from a girls coat) that is all she was wearing that night. I think you can still find fur in the car.
Oh I'm curious Streetwedg, what do you disagree with in my post #64 above?
