Lowe.n.behold
73 Dodge Charger 318 w30 heads 262 comp cam. So when I Google this it took me to many dodge truck forums but I still can't find an answer. Just got done installing new wiring harness behind dash.That is after I tried using a painless one. Got mad gutted car, redid seams and sound deadener and foam and new carpet. Installed a factory harness
and since car hasn't ran in 4 months. I checked fluids my brain doesn't work like it used to. It was good middle of range on dip stick! got car started. Ran bad so I adjusted the carb and got it running great then it died and when it would start it ran bad. Finally I hop in car to start it and the passenger floor is filled . Check oil and it doesnt register any more WTF
