Old dog still learning
M & M,
Here is a link to the guy I got mine from: http://www.powerbrakeservice.net/dodge--chrysler--plymouth.html
He has 2 for the 66 -70 MOPARs and this one specifically calls out a Charger. The other is for the rest of the B-Bodies. Contact him and verify that this is the correct unit..
This is actually my 2nd system. The first (different maker) had a piston failure and put aluminum particles into my P/S system. It contaminated and destroyed the pump and contaminated the power steering box as well. When we installed the new one, I put a filter in the line to trap any nasties. The one I uses is by Magnafine.
Jeff
Don't know why the "power steering" is showing up as a link??
Welcome aboard, I bet many of us could say we kept a few! Sweet Charger.
ray230
Awesome charger you have and congrats on holding on to it all these years. The '68 is my personal favorite of the Chargers, don't have one.........but maybe someday :clock:
I am very interested in how you solve your low line pressure problem on your disc conversion. I have the same problem on my '69 Bee. I'm using the smallest diameter bore M/C to increase line pressure, but way more pedal travel than I like and still marginal braking in my opinion. I would love to hear what your solution is.
Missiles,
I might have come across something! On the DodgeCharger forum in the brake section firefighter Ron posted a sticky of his experience with an SSBC install. Long story short, the instructions tell you to set the rear proportioning valve half way. This caused a hydro-lock to occur on the rear before the fronts had enough pressure. He opened it up all the way --and -- bam -- he had full pressure to the front too. I did the same tonight, and after a short around the block due to weather, I can tell the pedal feels MUCH better. Not stamping it fixed yet, but good feeling so far!
