Pipes sure look clean
You are running a cold plug and they can foul easy on a hemi probably even more so with a Stage V manifold and all that idle fuel and points. Granted you have high compression, but you might want to try a hotter plug as you sort this out.
I’ve been working on this hemi build trying to lean out the rich idle mixture and getting
nowhere with it. 496 stroke Hemi 11.5 to 1
compression with stage V custom heads the cam is a bullet roller [email protected] .638 lift
110 separation. Two 650 AVS2 carbs will be ran 1 to1 on the linkage and want use a factory PCV.
Here’s where i’ve been on it. Plugs are AR53
gapped at .032 running factory prestolite dual point distributor Initial timing at 18 degrees it idles at 1000 rpm and won’t idle any lower it just dies.
Has 10” of vacuum and is pretty steady the fuel mixture screws have little if any control
of idle speed. I have changed the main jets and rods twice to try to lower the amount of fuel but this has had no effect on the
mixture.
I pulled the carbs to check the idle transfer slot exposure and looked like too much. So I
Back the curb idle screws out and set them 1 turn in after contact but it will not run there.
In my research on these carbs it looks as the only way to adjust the idle mixture is with the mixture screws. It seems as the main jets regulate off idle and cruise and secondary jets wide open throttle.
I know the idle circuit get fuel from the main jet but it acts as if changing them doesn’t effect the issues I’m having with rich idle.
Want to try the NGK5ES plug but was hoping to get this rich thing corrected first. I’m getting fuel in the oil and it doesn’t take very long so i’ve changed oil twice now and around 1 hour run time for both combined.
So i’m here for Help and any ideas on tuning
these carbs. This is my first ever dual 4 barrel set up.
Yes all 3 are dual 4 barrel. But they are also AFB not AVS. My bet is the idle feed restriction and air bleed sizing is similar. Where are the idle mixture screws set? If the throttle plates are open excessively it need more air at idle. You could try wedging something in the secondary throttle plate stops to hold them open a touch to raise the idle speed.. Then see if the mixture screws function with the front plates nearly closed. If that works make it permanent or drill the plates 3/16".Doug,
Are your 3 cars dual 4 barrel setups? Only reason I ask is Khryslerkid mentioned you helped him with his setup. Thanks for replying here for (A) does 18 degrees initial sound low? (B) no converter it’s on the run stand (C) It”s possible it could have a vacuum leak does it seems that the vacuum gauge would not be steady if it did? I’m pretty much a newbie when it comes to a hemi and also to dual 4 barrel setups.
Doug
Bob,
I did have the PCV connected to the rear carb. The reason I called it Pig rich is because It’s smells rich not lean and all the plugs are black and fuel is going into the crankcase and needless to say but consuming a lot of fuel. I originally fired the engine up the first time without
the PCV connected still the same mixture though I have a carb sync and did sync the carbs.
With the comments and suggestions here I think I need to look at the ignition spark and the plug heat range and timing. The dual point distributor was rebuilt and recurved and setup on a Sun distributor machine by our very own Halifaxhops (Ray). I think having to open the primary throttle plates to get it to run is what I need to determine. I truly thank and respect everyone’s help and suggestions with my engine.
