themechanic
Oklahoma is OK
- 2:15 PM
- Nov 11, 2012
- Moore, Oklahoma
Check for exhaust leak at the flange gasket and at the header gasket. Could be letting fresh air in.
Uhhh...15 to 1 ??? Maybe with NON ethanol gas.Goal is as close to 14 as possible. Good range is 13.6 to 15.2 for most driving. O2 sensor wiring might be loose?
My car runs stronger at a mid 13 at cruise, mid to high 11s at WOT.
Yes. Never a hiccup. The fuel (tank/pump), plumbing and everything behind the firewall not so much. Edelbrock supplied components perfect. About 8k miles since install.Overall, are you happy with your Pro Flo 4 EFI? Thinking of making the leap with that or Holley Sniper.
Have they made it for the B block yet? I have a low deck 451. (400 motor)I still haven’t figured out why Edelbrock hasn’t made that for the b block.
Ricks Tanks. El Paso. Beautiful larger capacity tank. Too bad they plumbed the in tank Aeromotive pump with lines that were not immersible. Also pissed fuel at fill up until an elaborate vent system was put in. Resembles a catch can in my opinion. EFI a breeze. All the rest nothing but grief. Ricks never made good but admitted the problem. 3 cross country breakdowns probably cost 3k with repairs and lodging. Went there extra mile with the PWM pump. Didn’t do any good.
