Step 13: Drivetrain Upgrade, Part 3
Good Lord I've been slacking.
Okay, I got all the parts for the engine, and modified the K member to use the Schumacher mounts. This is a VERY easy process and took about 20 minutes with a grinding wheel and drill.
I also went and bought a used engine hoist off Craigslist for $150, and I plan to sell it to someone else for the same amount, so that's a push budget wise.
I removed the hood and installed the engine and trans as one unit... by myself, which is no fun. One trick I learned was to tie a length of rope to the tailshaft of the transmission, and feed the rope over the transmission crossmember, under the car, and back to you. As you lower the engine/trans into the engine bay, keep pulling on the rope and guide the trans up and over the crossmember.
Made the job pretty easy.
What made the job pretty hard was I had put both headers on before install, and the passenger-side header was no problem but the driver's side hit the power steering. I had to stop and pull the driver's-side header off, install the engine, then install the header again - after banging it with a hammer to make it fit.
Another issue I had is going from a small block to a big block with an Edelbrock Performer intake, spreadbore to squarebore adapter, heat gasket, and Edelbrock carb, there was no way the stock throttle cable and bracket was going to work. I had to buy a new extended cable off ebay for $29.
The throttle bracket was a different problem. The Town & Country I got the powertrain from had cruise control, and the bracket for these cars has a second, higher, clamp for the cruise control cable, but even that was too short by about 2". The fix was I cut the tabs that support the bracket off, and made two 2" extenders out of 1" x 1/8" steel stock, and welded the extenders between the tabs and bracket so it is now ugly but two inches higher and functional.
When I fired the engine up, I was very pleased that the new aluminum radiator is working well and the temp gauge sits right where it should. What didn't work well was the two cans of white header paint I put on the headers. Yep, as soon as those headers heated up, that paint was smoking and peeling, so don't waste your money on that crap. I bought two sections of flex pipe from Advance Auto Parts for $20, and used that to connect the headers to the exhaust pipes. This is a temp fix and I expect to pay about $150 to have an exhaust shop make me some real connectors.
