- 10:26 AM
- Mar 28, 2014
- South Louisiana
How much space do you leave between the pinion snubber and the body?
When I installed Mancini's top of the line pinion snubber on my Dana 60 in my 70 Roadrunner, there wasn't much room even with the vertical threaded snubber screwed all the way down (as short as it gets). That may be one indication of what I suspect are worn out factory original HP leaf springs. Then the horizontal component of the snubber bracket bent on the first run, and again on the 2nd run to where I had to remove it.The snubber adjustment depends on how you want to drive the car. On the lower setting it is more effective than the stock snubber, but will still allow some wheelspin. On the upper setting it's much more effective as a traction device, it allows the leaf springs to wind up just enough to prevent wheels hop.
That made me think that the springs were shot. Unfortunately my friends I had with me at the track were too incompetent to shoot a video, but worn out springs seem to make sense.
Regardless, I already bought Calvert split mono leaf springs and Assassin traction bars, and I'm looking forward to seeing how that works.
