Studs.
The system was dry other than what residual fluid was in the steering box. I filled the reservoir and had Mary saw the wheel once the engine started. I added fluid to keep the level up. It never made that grinding noise they make when they are low.I did my rear main twice, and it still leaks. I am going back to a rope seal next time.
I also had a screeching noise from the engine's left after I changed the intake and carb. It turned out to be the PCV valve. I never noticed it before.
Did you bleed the P/S system?
I shined a light up in the back of the block with the engine running and the gallery plugs are dry. The side of the seal retainer appears dry.I honestly think most rear seal leaks aren't the seal at all... I think most of the leaks are the side seals... I've heard of a few folks having trouble with the billet seal retainers leaking from the side seals too...
I used the stock seal retainer & I fill the V shaped cavity on the rear of the engine with "the right stuff"... I've had pretty good luck doing it that way...
I do shove the valve covers UP before snugging the bolts down. That does seem to help since the valve cover gasket rail seems to be overall wider than the rail on the heads. Gravity allows the oil to rest on the lower rear area and if the covers are allowed to slide down, that area that I highlighted has even less contact.On the valve cover gaskets, I have found that it helps to push the cover up towards the carb before snugging up the screws. As far as the rear main seal, that area seems to have really gotten problematic in the past couple of years. My 451 is leaking around the crank after a freshening up with new bearings and gaskets. The engine builder sent it home with me last spring and was it leaking terribly. He told me to pull the motor and bring it back. He had it for 2 months and had it on the dyno 8 times. Finally put a rope seal in it and sent it back to me. I put it in the car, and guess what, it still leaks. That's why I asked you what kind of seal system you went with a couple of pages ago....
I pulled the master cylinder to bench bleed it. When I first installed it to the hydroboost unit, I did so to have it in place to form the brake lines. I knew it would have to come back out to bench bleed.
Make note of the following:
Stainless steel, pan head screws S U C K in this application.
These are what Dr Diff included in the kit to attach the master cylinder to the Hydroboost unit. They look great but the smooth finish makes them hard to thread by hand. I put anti-seize on the threads even though the HB is iron. The access to install these is crowded with the brake lines and hydraulic lines in place so a standard 6 point hex fastener is a better idea. You can grip them and thread them in much easier.
