I had to gut my distribution block on my four wheel disc brakes, they work excellent now.
10" - yikes.This car had 4 wheel 10" non power drums when I bought it. It actually stopped okay. Not great but okay.
In 2012, I was curious about trying a 4 wheel disc and manual master cylinder arrangement. After trying 4 different master cylinders of differing sizes, I put the power stuff back on because I couldn't get the brakes to feel right. All 4 setups gave a hard pedal and terrible braking. Months afterwards, I saw that I had a disc/drum proportioning valve in place. Maybe I would have had better results with NO proportioning valve. Also, I had those big 2.75" iron front calipers with 1.5" rear calipers. I suspect that the front to rear bias was way off. The Mopar setup of a large caliper up front was matched to self energizing rear drums and a fixed proportioning valve. Even those cars sometimes had rear wheel lockup.
Now I have 13" front rotors with dual 1.59" calipers and the same 11.7" rear rotor size with 1.5" single piston calipers. This is an OEM setup for a 1994-2001 Mustang GT.
In June of this year, I started making some changes.Although a Mustang is I'd imagine a smaller. lighter car than the Charger - those sizes seem more than adequate to me.
What did you not like about that setup?
I can tell you that if you disregard brake fade with repeated fast speed braking, the 2 manual drum cars I've driven both stopped very well. One is Dennis H's 1969 Coronet RT with 440 (about the same weight as your car - 3800-3900 lbs) and the other was my 1967 Impala SS with 327 that I drove as a daily driver for 15 yrs (was my dad's old car). That one had 11" manual drums all around and I never wanted for braking power. At sub-20 mph speeds I could get it to stop fairly quickly and it wasn't that much of a leg workout and had excellent pedal feel. That car weighed about 3500 lbs.I've read that cars as heavy as mine are hard to stop with a manual master cylinder. That may be true. The car weighed 3940 before tearing it down in June. The Borgeson steering box and stock Idler and Pitman arms shaved 14 lbs. The new front brakes shaved another 14 despite the larger rotors. The switch from the A body vacuum booster and iron MC was another 15 lbs. I swapped rear tires for ones with shorter sidewalls. With all of this, I could be under 3900 with these changes.
the VR1 is synthetic high zinc and your car ran great for 5 yrs on this stuff.There are some things that we never fully understand.
I believe that the problem originated with the oil. The engine ran fine for years with Valvoline VR1. It failed within a year with this weird high detergent synthetic oil. One or two lobes usually means a tight lifter bore or a lifter that isn't rotating but I had 10 lobes all failing about the same time.
You can buy VR1 in a non synthetic as well. That's what I run anyway....the VR1 is synthetic high zinc and your car ran great for 5 yrs on this stuff.
What high detergent synthetic oil caused the motor's demise and why had you switched from VR1?
didn't know that!You can buy VR1 in a non synthetic as well. That's what I run anyway....
What the evidence is starting to indicate, yes - that HB unit is the unproven wild card in the equation, after all.I tried bleeding the hydraulic system using the method shown in post #666. It did not help at all.
In fact, the steering assist now is struggling. With the other pump, the rebuilt one, the steering assist did work at first but the HB never did. Then it got to where the steering assist was notch and only at higher rpm’s.
Now it seems that this pump is starting to fail. The steering assist worked fine but the HB didn’t. It is showing the same symptoms as the other pump before it quit completely. This is extremely annoying. The belt doesn’t appear to be slipping. It isn’t squealing. Can it be that this hydroboost unit is killing these pumps ? I’m going to feed the steering box directly from the pump to see if it works normally that way. I’ll report back soon.
What type of cam are you running and in what engine?didn't know that!
KD, can you clarify if the VR1 you ran for 5 years without trouble was conventional or synthetic?
I'm using Amsoil 10-40 Z-rod synthetic and no issues on my motor.
This has been proven to me before my own eyes as well for a number of years now.You can buy VR1 in a non synthetic as well. That's what I run anyway....
451 big block with a mild Lunati Voodoo 60302 hydraulic flat tappet cam. 0.475" lift and duration at .050" is 220/226, 112 deg LCAWhat type of cam are you running and in what engine?
