Reasonable upgrades for cruisers
Flint
6:28 AM
NE Kansas
69 Road runner. I’m to the point of selecting some suspension and steering upgrades but don’t don’t want to go wild to make it a somewhat reasonable driving car with newer radial tires. Just a few thoughts so far are Bergman steering box, Box in LCA’s, total bushing, rod ends and joints replacement. Maybe some torque box/subframe reinforcement.
Not making a road race or auto cross car. So do I want rubber or poly bushings? Do I want to install some aftermarket UCA’s?
Trying to get rid of some of the feeling of driving on a cloud of ******* as I’ve seen being referenced.
The basics are stiffening the unibody. Upgrading the torsion bars and shocks. Sway bar. Good radial tire with a modern alignment spec.
Any particular brand and size of these parts? Is the (modern alignment) possible with stock type components? I did do some reading here but it mainly turned into long controversy.
The box will tighten up steering
Box in LCA’s,
will do nothing
standard rebuild program
good idea
rubber
All that will do is get you closer to better alignment specs.. most importantly added caster
It's not as bad as it sounds lol
Thanks. I’m 60 and have owned and driven a few over the years. I had the firm feel box in my 67RT and it was half *** but nothing special. Lots of changes available since then, 20ish years ago.
Mine is a 383 car and plan on low deck stroker with Aluminum heads , intake and water pump assembly. So RB or Hemi torsion bars or something else?
-Front and rear Hellwig sway bars
-Bilstein RCD shocks
-Moog 7103 offset upper control arm bushing installed for more caster (not per instructions)
-12” front disks with Dr Diff caliper adapters
-Everything else stock.
Sub-frame connectors..
Weld in is best. You could bolt them into position, then weld once in place. Make sure the car is supported correctly beforehand though. Tires/wheels on cribbing, elevated high enough for work clearance or car on a 4 post lift. This way the car is loaded like normal and you can open/close doors without issues. If it's an empty shell, a two post will work. Some of the weld in versions will require you to take the interior out also. Like the USCT versions or the diy rectangle tube version like I and many others have done.
