roadrunnerman
Don't know about past sins, more like coming back to haunt me.
Well, I gotta admit that I was the one that put it there back in the late 80's when I went to trade school (bodyshop). The last 2 weeks of our course, the trainers would let us bring our own cars in to work on. My car had a wrinkle down the whole side from a garage door frame. I didn't do it. So I had 2 weeks to strip car to bare metal, seal it, do the bodywork primer and paint. The lower part of that 1/4 has at least 3/4 inch of body filler on it. Fast forward 20 years, here I am.
No disrespect was taken in your comment. You and both know 20-30 years ago, they didn't have a lot of replacement parts like they do now.Didn't mean any disrespect about the filler. I did the same thing on a Cuda I had 30 years ago. Young and didn't know any better. And a year after paint it was bubbling up again.
Wow...That's a lot of Makeup on the old girl. Look at the brightside Roger...Not only will you be getting rid of that bondo covered rust, but you'll probably lighten up the car quite a bit once that stuff is out of there. I'd agree with basketcase, full skins...skip the full quarters if you can and buy the window corner patches. Save yourself some jing and time. New AMD full quarters 1,100 pr....skins 660 pr.
I've got the corner pieces and I will probably go the full skins on both sides.Wow...That's a lot of Makeup on the old girl. Look at the brightside Roger...Not only will you be getting rid of that bondo covered rust, but you'll probably lighten up the car quite a bit once that stuff is out of there. I'd agree with basketcase, full skins...skip the full quarters if you can and buy the window corner patches. Save yourself some jing and time. New AMD full quarters 1,100 pr....skins 660 pr.
Or $400 a pair for the Goodmark skins,i used them and they fit fine.
Thanks. And no, nobody else has mentioned anything like that but I appreciate that you did. That one picture does show that I did tack weld, but I was not finished when I took that photo. I did add several more welds and also seam welded in a few other spots. Don't know if this was correct or not, but I put a flange in for the new piece. I knew I couldn't butt weld and I didn't want an overlap, so if someone can say right or wrong on the way I did it, please let me know. The vinyl top is going back on but I still want it as smooth as possible. Thanks. Forgot to ask, what did you use to seal underneath?
