- 4:34 AM
- Jan 1, 2013
- Mascoutah, Illinois
I agree .. cool story roger
Well, i'm not losing any sleep over it, beside, how many mice had a guest house in the heater assembly?....... OK most of them did. LOLjust think of more homeless mousies...oh the tragedity.......
Roger, the cowl is very easily removed to expose the air intakes, I replaced mine and used one that I had saved from a 1968 RR. Unlike some stubborn panels the cowl comes right off once you drill out the spot welds. The one problem I ran into was sealing it back up, from the factory there is some sort of foam looking sealant between the panels. I used weld threw primer on the surfaces and once installed I used latex gloves and short paint brushes to reach inside the air ducts and smear brush on seam sealer to the seam "pain in the @%*. Another thing I did while I was at it that I'd suggest everyone doing is install some sort of screen over the water drains. That's where those critters get in, I bent some stainless expanded steal to fit over it and then just pop riveted it to the top. I know that it will not allow leaves to get out but my car will be in the garage most of the time where the critters do their damage, nothing ticks me off more than mice wreaking havoc on the interior. Keep up the good work
never had nests in the heater, Ohio mice seem to like the frame rails.
