wyrmrider
great postI have been doing engines since I was an apprentice and had never heard of rocker geometry until I purchased an engine blueprinting book about 25 or so years ago.
At least you knew to check it.
That video from Straub is pretty good but the old way of centre of valve at half cam lift still works fine. I have done quite a few engines over the years and your eye is pretty good.
The sweep of the rocker over the valve tip is fairly important. If your sweep on a Mopar is around or less than 1 mm or 0.040 thou you are doing pretty good. A little bit off centre will cause no issues. With the shaft mounted rockers you cannot alter the rocker geometry with push rod length as described in the video.
To alter the geometry on a Mopar you need to move the rocker shaft up or down. It would be nice to move it in or away from the valve also but as we know that cannot happen with the cast in pedestals. A Mopar rocker is pretty short and that is some of the trouble.
To optimise the push rod length put a DTI on the spring retainer and play with the push rod length until you get the most valve lift.
Have the adjuster screw far enough out of the rocker to ensure it is low enough for oil to spray in to the push rod cup. If your push rod is too long I believe you can starve the rocker end of the push rod a bit.
I modify the Harland Sharp, the push rod oiling hole is huge and no oil goes to the rocker tip. I only buy the Hughes ones now.
I will
couple of things
you can mill off the stands and use new stands to move the shafts up and back- or use B3s kits
Getting max lift method implies that you have the shafts really low making the rocker perpendicular at near max lift
max increases load over nd accelerationa near the nose rquiring tiffer springs
you want most leverage at mis lift so you can slow down to get over the nose
you can't correct geometry with shaft rockers via pushrod length as you can with stud rockers- after moving the fulcrum
going 4 minimum stripe works but you hav to move the shaft
pushrod length is an afterthought
I'll watch the video
most write ups on camgrinders websites do not apply to mopar
read the 4 tech articles on the B3 racing website
