Well we have gotten a lot finished but there's still a bit to do... New engine is in as well as: new torque converter, new 727, shortened balanced and rebuilt driveshaft with new u-joints, new ceramic coated headers, new starter, new ignition system, new carb is on and we are almost finished with the throttle and kickdown linkage, plus I took the time to completely rebuild the rear brakes since the rear wheel cylinders leaked out while I was doing the paint and body, then I serviced the rear end, and I undercoated the whole car, plus a bunch of other necessary odds and ends.
Those T bolts on the valve covers will be coming off once we run the engine and if necessary adjust the lash if it turns out that we need to after the engine has warmed up. I don't like the looks of those.
We made some aluminum brackets and carefully routed the Taylor plug wires away from the headers.
We still have to figure out which pulleys we are going to use and mount the new alternator and new power steering pump.
My new cooling system started showing up today but we haven't gotten to it yet. I kinda went all out on that. It's a 4 core 26" aluminum radiator from Champion. I also got the aluminum fan shroud for it with 2 12" electric cooling fans plus the relay kit and a SS overflow. That should keep it nice and cool in the Texas heat this summer.
I still have to find an air cleaner for it that won't interfere with the closing of the hood. Plus we got a new power brake booster and master cylinder for it, because the old ones just look bad, so we still need to install that and bleed the brakes down. And I need to clean up the wiring a bit and route it better.
I will say that I am quite surprised and happy with the headers I got from Jeg's. I got some ceramic coated headers from them and the things were a breeze to install. I had tried another set but they had hit on all kinds of stuff but the ones from Jegs really just slipped right in and once in, only required a nudge with the prybar by the power steering box to give them a little room to move. I will say though that I hope the starter never goes out while I have the car because if it does, it will be a bit of a pain in the *** to swap out. Definitely not something you'd want to try and do anywhere but at home or up on a lift preferably.
I'm hoping we should just about have everything finished out next week. We will see.
