Butch Harley
SCARED!!!!!!!!!! six pack manifold maybe if I use all 12 bolt holes
And, when bolts are used in a clamping load situation the breakaway strength is much higher!I use them all the time. The max tensile strength on a grade 8 5/16"-18 bolt is 7850lb times the stress area in in^2 is 7850*0.0524= 411.34 lbs.
Approximate a 800lb motor /4 = 200lbs per bolt. You are only at half of the allowable load on each bolt and honestly, most motors are less than 600lb.
I ain't skeert, even with aluminum manifolds...
But the numbers involved would be lower if you guys used Metric.And, when bolts are used in a clamping load situation the breakaway strength is much higher!
....and then the fight started....
Sgt Hulka!...Any one of you "Suck Holes" wanna come up here and knock me off...
and
...Sgt, does this mean we're done for the day...
2 AWSOME lines!!
The "Big Toe"!!Sgt Hulka!
