bandit
I need some help diagnosing a problem.
Took the car out last week and was getting smoke rolling out from the back passenger tire around the drum when I got home. Pulled the tire and drum, and the brakes are not dragging and I see no fluid leaks. Turned the hub in neutral and not hearing anything(trying to listen for bad bearings noise)
Took it out again today just to confirm and the same thing, smoke rolling out from the drum on that one side when I got home. Holding my hand close to the rim, I can also feel it is heating up pretty good.
From reading, my suspicion is the bearing and/or seal but just a guess at this point. Again I did not hear the typical bad bearing noise and saw no apparent leak. Figure I need to pull the axle at this point but any tips on what I should be looking for? Never pulled one out before.
It's a Dana 60 Sure Grip if it matters.
