451Mopar
Just scanned through this. Combination looks OK. Put it together, use good oil and break-in additive, prime the oil system, and get it tuned correctly. You will need the MSD dist advance kit if it did not come with the distributor. I would try the blue bushing, and the two blue light springs, then set initial timming to about 16 degrees. This should give you 36-37 degrees all in around 2,800 RPM.
