Stock Radiator Fan or Electric Radiator Fans
UncleAl
7:55 AM
Myrtle Beach, SC
I have a '69 Charger R/T with a 440 engine and the stock fan. There is currently no fan shroud and it has a 24 inch aftermarket aluminum radiator. This car will be for cruising around and going to and from shows. It originally had factory air, which is missing, but I intend to reinstall because being in my 70's and living in SC, I don't want to swelter in a car with a black vinyl top and black vinyl interior.
My question is, do I install the shroud on the factory radiator fan and keep the factory fan and deal with the loss in horsepower (HP), keeping in mind that I will be losing more HP when the AC is reinstalled, or lose the factory radiator fan and shroud and install electric radiator fans? By installing electric fans, I regain some of the HP I'll be losing from installing the AC, but can the cost of such a change be justified? Thoughts?
You don't think a highly loaded alternator, to run those fans, doesn't kill as much HP as running a factory water pump fan?
In is my theory that Ma Mopar had it figured out already, so why reinvent the wheel ie the cooling system. JMO
Short answer is I do not know.
Long answer. My old 78 Chev did not overheat, even with a single core radiator. Hauling heavy loads, such as 110 bales of hay in the gooseneck trailer. Credit went to the shroud behind the radiator.
Fast forward. My 77 B200 camper van, is a bit under powered with the 318. It has a shroud for the fan, and a recently purchased old school radiator. I will be installing an electric powered fan and attaching it to the shroud. My thinking without getting scientific, is that most of the time, the fan will not be needed. I will turn it on when I see about 180F. What extra load the alternator may draw, is not being considered, as it is turning full time anyway, and supplying about 14.5 volts. Just in case, I will carry the original fan with me.
I dont understand why so many people want to change something that is not broke. Factory setup is the way to go. JMO
The HP consumed by the alternator is dependent on the AMPERAGE produced not the voltage. Electric cooling fan(s) can consume, depending on brand, CFM ( cubic ft of air moved at a specific static pressure) 20 to 30 amps at 12 volts is not unreasonable.....then the alternator and wiring system will need upgraded. IMO.....Use a thermal drive clutch with a 7 blade fan and shroud, exactly what MOPAR intended when equipped with A/C......
BOB RENTON
