Opposite ends of the cow. The brisket is the neck. Tri tip is tip of the sirloin close to the back leg.What’s the difference between brisket and tri tip?
I have a hard time finding it here. We have a Fairway grocery chain here that has a big meat counter and I think I should be able to get some there. It's fun to walk in and hear the meat saw singing in the back of the store.My wife is having a hard time finding tri-tip here in Texas.
Tried to buy a tri tip a few years back while on vacation at the Outer Banks, NC. Dudes at the store looked at me like I had three heads. The more I tried to explain what I was looking for the worse it got.My wife is having a hard time finding tri-tip here in Texas.
I have a cast iron pan that fits my small Old Smoky just right.....but why is cast iron bad to use on an electric stove? I did some burgers on the stove recently and man, rather do them on the OS.I'm not ashamed to admit that the way I do ribeye is basically from a Gordon Ramsay video.
Of all the ways it can be done, I've tried most of them. Some are better than others...
These days, it's real simple for me:
- Pan medium-high temp; it's ready when a small amount of oil just starts to smoke
(since I don't use my beloved cast iron much anymore due to glass top stove, this means a
good heavy stainless one with a brass base - yes, electric stoves suck)
- Steaks are out of the fridge 20 minutes minimum before cooking; light brush with oil, liberal
amounts of fresh-ground salt and pepper rubbed in all sides (more than you think you need)
- Steaks in, going for a quick sear on both sides - depends on thickness, usually about a minute
to a minute and a half
- After second flip, introduce butter and fresh chopped garlic into the pan. Baste steaks liberally
for a minute; flip one last time, repeating basting process
- Pull them out the pan to relax on the plate for a couple minutes
Not only about the easiest way to do ribeyes, but about the tastiest way also - and it works great
on the sort of steaks typically available on sale at the local chain grocery, which let's face it -
aren't exactly the best quality in the world.
I've never heard this? I think it might be the reason that electric is a more concentrated heat than gas that can warp cast iron if you're not careful? Also electric takes longer to cool down over gas, so that could be the reason too? My C.I seems to get hotter with electric, I have a glass top stove and when I turn it on to high, it's hot right off the bat compared to the coil type electric that seems to take forever to heat up. You really have to pay attention, that's for sure!...but why is cast iron bad to use on an electric stove?
Mine is a glass top too. What I don't like about gas is that it throws off a lot of heat. Great in the winter time but not so good in the summer....plus having gas isn't all the cheap anymore.I've never heard this? I think it might be the reason that electric is a more concentrated heat than gas that can warp cast iron if you're not careful? Also electric takes longer to cool down over gas, so that could be the reason too? My C.I seems to get hotter with electric, I have a glass top stove and when I turn it on to high, it's hot right off the bat compared to the coil type electric that seems to take forever to heat up. You really have to pay attention, that's for sure!
Purely to avoid scratching the glass. Cast iron works fine otherwise on these stoves if you don't mind the damage.I have a cast iron pan that fits my small Old Smoky just right.....but why is cast iron bad to use on an electric stove? I did some burgers on the stove recently and man, rather do them on the OS.
