That idea helps in most cases. I didn't think it would work here since the gap between the transmission face and the bell was about 5/8" maybe 3/4". I don't know if the throwout bearing operates much further than one inch.
The bolts SST supplied were too short to use until the trans was seated. They are not long enough to draw the trans to the bell. The long stack of spacers attached to the front of the transmission was already partially through the bellhousing hole. The damn things could have been machined a couple thousandths under to make fitment easier.
When I did my Tremec swap, this was the hardest part
physically speaking. Yeah, I struggled with figuring out the dial indicator and it's awkward arrangement as well as the runout procedure but the act of trying to press a transmission forward while pushing overhead isn't easy, The exhaust was in the way of getting much leverage too. It shouldn't be such a tight fit.
The second time I installed this transmission, I had the engine out of the car so I had all sorts of room...
With the extra room and leverage of working overhead, it did go in easier but was still a struggle.
Now here is the 3rd time I've dealt with the tight fit with mating the transmission to the bellhousing. I'd like to hear from others that have noticed the same thing.
One thing Rich surely meant to mention:
The TKX is a slimmer unit compared to the TKO. The top edges are rounded off on the TKX. As a result, the cutting of the floor pan is less involved and actually limited to just the rectangle of the shifter tower.
SST includes a template on where to cut the floor for clearance.....
for the TKO series!
If an inexperienced installer were to follow the instructions as directed, they'd end up cutting a hole a lot bigger than necessary. This isn't a big problem with a center console to hide it all....
For those that have no console, the shape of the finished floor matters a lot more. There is more detailed carpet fitment issues with a "doghouse" on the tunnel.
