Michael R/T
Great thread, thank you all for posting
I watched the SST YT video on measuring TIR. They did it in 9 minutes, how hard could it be?I've been to the roof and back and told the stories.
I still have no fear of doing the work and that is a good thing. Fear may keep you safe but it also kills the spirit of a man. I'd rather risk a bit to get stuff done than to play it safe from the couch the rest of my life.
I went back through my own Tremec installation thread to familiarize myself with some tasks that are coming. 40 page threads take awhile to get through.
Rich won't have many of the distractions that I had with my project.
He is starting with a column shift car with no console. There is no modifying the console parts and his original carpet will be reused.
No need to repaint his headers, no oil pan-valve cover-intake leaks to address, his flywheel will probably fit without machine work too.
The TKX has a rounder top that is supposed to fit without the sunroof sized hole I had to cut in mine. NO "doghouse" to cover the hole either.
For me, the two most difficult parts were the measuring of the bell housing runout and the final stuffing of the transmission into the car.
I love to learn from my past mistakes so here is what I've thought of.
If Rich wants, I'll modify the linkage rods of my dial indicator by shortening them to allow the needle to point at 90 degrees instead of this angle:
Next, some light lube on the input shaft and the pilot bearing may help the interface. I understand Rich's kit comes with a trans yoke but not a drive shaft. Slipping the yoke onto the output shaft would allow movement of the input shaft in case the splines are butting into each other instead of meshing.
I'm open to any suggestions as I'm sure Rich is.
All the paperwork and parts are at Greg's shop, but I don't remember ordering a yoke. I was planning on using a local driveline shop to modify the driveshaft, although Greg reminded me that the driveshaft has to be lengthened, not shortened like I was anticipating. I may winding up going back to SST for the driveshaft.My buddy who’s doing the TKX swap, his kit from SST didn’t include a trans joke or a driveshaft, both are extra.
I wish I can help you guys, I love working on these old cars.
Greg take it easy with that bad disk, you don’t want to permanently damage your back
I tend to grab driveshafts out of C bodies... They are longer and can be cut down...All the paperwork and parts are at Greg's shop, but I don't remember ordering a yoke. I was planning on using a local driveline shop to modify the driveshaft, although Greg reminded me that the driveshaft has to be lengthened, not shortened like I was anticipating. I may winding up going back to SST for the driveshaft.
Do you remember what offset you used on your Charger?These dowels are from Robb MC (spelling ?) and they are the .014 offset style.
That post I made showed the engine and transmission from my car. .014.Do you remember what offset you used on your Charger?
Lol, there aren't any shortcuts. It is just a boring, time consuming deal to get it dialed in.This whole process is tedious and frustrating, almost like putting headers in a Mopar for the first time. Maybe it gets easier with experience but I haven't done it enough times to know the short cuts.
We all need to agree upon a place and start a neighborhood!Yeah, I'm in the same boat as you. There are several members on this site that I wish were my neighbors.
Yes! A stable surface to mount the base is Job 1. Your photo is very close to our final setup. We spent a lot of time trying the align the indicator so it would land in the center of the register, but the circumference is too small so it wound up off center like yours. The key is to pre-load the plunger so when the indicator rotates, the top of the plunger doesn't make contact with the surface.Greg and Rich:
I needed the offset dowels as well. I ordered two sets (they adjust by differing amounts) and I now forget which ones I used. The key for me was to make sure I had a stable base to connect the magnetic clamp to so my gauge would not move. I suggest spending some time on this. I slapped mine on at first and then suffered the consequences of non-repeatable numbers. Once I had the base stable, I got repeatable numbers and was able to fairly quickly adjust the dowels to get everything in spec.
Good luck guys!!!![]()
Picking a random starting point (close to 6:00 on the register), Greg rotated the crank while I watched for the high spot. The high spot hit at about 2:00 and was .082"! Not -.018". Greg continued rotating until the indicator plunger was 180° from the high spot, and the indicator dropped back down to 0.00". We had to have done something wrong. But we did another sweep and repeated the .082" TIR. Next, we installed Greg's indicator onto the base and I rotated the crank while Greg measured, and this time it measured .079" and -.001"; almost an exact match. That's where the yelling and cursing comes in.
I talked to a SST tech this morning. He first wants me to verify the mating surface of the block is thoroughly clean. Even a coat of paint can significantly alter the measurements.
I did clean the surface yesterday with brake cleaner and rag, but maybe it wasn't enough. The block was painted during the rebuild and maybe the paint is uneven on the mating surface.
Another thought is the dowel pins that are in the block. Greg had noticed after the auto was pulled that the dowel pins weren't tapered at the ends like OEM. They're cylindrical with the same diameter through the entire length. The 440 is not the original block, maybe not even the original tranny, so possibly the dowels were replaced with aftermarket? The dowels could be off .080".
I'll prep the block more thoroughly before we remeasure.I lightly sanded my block to make sure the mounting surface had no paint on it. However, I can't imagine uneven paint causing a .082" error!
So dumb question here, and forgive me if I missed, or misinterpreted something: You talk about the dowel pins in the block. But they need to come out in order to put the offset dowels in.
Was the .082" measurement before you put the offset dowels in (i.e. the original dowel pins)?
If so, I would pull the old dowels, clean up the mating surface, and then put the smaller offset dowels in. Throw them in "wherever", perhaps with them somewhat towards where your large error was. Then remeasure and see what you get. Best to start with a fresh clean dowel you can readily adjust and you know was not put in cocked, etc.
Time consuming yes. Not boring. It's been a frustrating, anxiety-inducing, hair-pulling, foot-stomping process. But not boring.Lol, there aren't any shortcuts. It is just a boring, time consuming deal to get it dialed in.
Do you have a dowel pin remover?I was just about to post a question about removing the dowels.
